2025.1
Explore the tools used to create topology.
Learn about creating, editing, and extracting points and nodes.
View new features for Altair HyperWorks 2025.1.
Define topology preferences.
Explore the tools used to setup topology.
A point is a zero-dimensional geometric entity.
Nodes are the most basic finite element entity. A node represents a physical position on the structure being modeled.
Use the Create Points/Nodes tool to create and edit points/free nodes on geometry surfaces and lines or in space.
Control which nodes are on the temporary node mark.
Create evenly spaced or biased nodes by interpolating between existing nodes in space, on a surface, or on a curved or straight line.
Use the Extract Points/Nodes tool to interpolate and divide an edge or line, and find the center of an arc, fillet, or multiple curve segments.
Create and edit circles and rectangles with the Shapes tool.
A line represents a curve in space and is not attached to any surface or solid. A line is a one-dimensional geometric entity.
Use the Ruled tools to create surfaces/solids by interpolating lines and surfaces either linearly or smoothly.
A face is a single Non-uniform Rational B-Spline (NURBS) and is the smallest area entity. It has a separate underlying mathematical definition, specified when it was created.
Use the Extrude/Revolve tool to drag and spin lines, surfaces, and nodes in order to create surfaces or solids.
Use the Offset tool to offset surfaces, solids, lines, elements, or faces.
Use the Midlines tool to create midlines from existing lines, surface edges, or tube solids.
Use the Extract tool to convert sketches into geometry lines and surfaces with the realize option. Delete lines and surfaces converted from a sketch entity with the unrealize option.
Use the Ribs tool to create and modify simple ribs between two surfaces.
Use the Feature Edges tool to create and edit mesh controls on an edge.
Explore the tools used to edit topology.
The Use Parasolid option, found in multiple Topology tools, helps you in creating/editing geometries using a parasolid geometry modeling kernel.
The Developer ribbon contains tools for automation and customization.
Plot data can be post-processed using both HyperMesh and HyperGraph.
