Use the Auto Offset tool to restore the position of members after associated sections
have been edited.
In the Skeleton workflow, when member sections sketches are edited, it's necessary to
restore the original member position. This is due to the new shear center position.
In these cases, the Auto Offset tool should be used.Figure 1. Original Section with Right Offset but Wrong Sketch Figure 2. Section Sketch Before Editing Figure 3. Fixed Sketch and New Shear Center Position Figure 4. Fixed Sketch Section with Wrong Offset
From the Skeleton ribbon, click the Auto Offset
tool.
Figure 5.
Select members or member sections to be adjusted.
Note: Only connected members and member sections are supported.
