Categorize Model
Use the Categorize tool to streamline the development of reduced order models by automating the detection and categorization of subsections within an automotive model.
It classifies these subsections into four groups: Skeleton, Panels, Castings, Glazings, and Hardpoints, organizing the content into corresponding sets.
After categorization, the next step in creating the reduced order model is extracting a mid-line representation from the skeleton subsection. Once this mid-line is created, the final step is to use skeleton absorb, which converts the mid-line input into a 1D mesh with detailed beam sections applied. The accuracy and organization of these sets are critical, as cleaner categorization reduces manual intervention and clean-up times in later stages, particularly during the line extraction and absorption phases.
The Categorize tool can handle various inputs, including:
  • ICE vs EV models
  • Different vehicle types (coupe, sedan, SUV)
  • Glazing configurations (panoramic vs fixed roof)
  • Manufacturing processes (extrusion vs stamped)
  • Castings (single part vs megacastings, shell vs solid elements)
  • Glazings (shell vs solid)
  • Joining techniques (rivets, spotwelds, adhesive)
The categorization output is organized into sets prefixed with DFEM (Detailed Finite Element Model), following a naming convention like DFEM Skeleton 1, DFEM Panels 1, and so on. If Categorize is run multiple times, the numbering increments increase. It is essential to review the sets to ensure everything has been correctly detected, with any necessary manual adjustments made to ensure accurate classification.
  1. From the Skeleton ribbon, select the Categorize tool.
  2. Select components, elements, or parts.
  3. Click to define options.
    General
    Fill holes, max width
    Fill holes in selected input. The default is 10.
    Retain fill holes elements
    All elements created during the fill hole operation are kept.
    Exclude parts with small E, max
    Remove all parts with small Young’s modulus. The default is 20,000.
    Exclude skin elements (thickness <)
    Remove all elements with small thickness. The daefault is < 0.01.
    Exclude parts with low volume (<)
    Remove parts with low volume. The default is < 30,000.
    Hardpoints
    Find adjacent
    Detects the rows of elements out from the select hardpoint location and will be categorized as part of the hardpoint.
    Ratio
    The ratio of elements identified by the find adjacent factor to the total number of elements in the entire component that the identified element belongs to is then used to place the entire component into the set.
    Find tied contacts
    Detects hardpoints and surrounding structure via tie connection as opposed to physical connection.
    Glazings
    Find adjacent faces
    Find the faces that are adjacent to features. The default is 15x.
    Find only above Z-plane
    Consider glazings above the user defined Z-plane.
    Use CofG
    Consider glazings above the auto-calculated or user defined CofG.
    Find attachments and glazing flange
    Find the rows of elements around and attached to the adhesive on the glazing.
    Find tied contacts
    In addition to physically attached, include tied contacts.
    Castings
    Include hardpoints in output set
    Controls the location of the hardpoint information. It will reside in its own set or be included in the castings set.
    Panels
    Cleanup area size
    All patches less than the size specified will be removed from the panel set.
    Controls the location of the hardpoint information. It will reside in its own set or be included in the panels set.
    Connect to panelset
    Connects the panel set contents to the surrounding structure found in the hardpoints, glazings, and skeleton output.
    Skeleton
    Fills holes so that the skeleton set can be calculated. The default is 500.
    Tolerance
    Tolerance used to generate the skeleton set. Use a large value for cruder output, smaller for more refined. The default is 20.
  4. Optional: Select hardpoints.
  5. On the guide bar, complete one of the following:
    • Click to apply and stay in the tool.
    • Click to apply and close the tool.
    • Click to exit the tool without applying.
