*CONSTRAINED_SPOTWELD
LS-DYNA Input Interface KeywordDefine a connection between 2 nodes with a possible force based failure model.
| (1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
| *CONSTRAINED_SPOTWELD_{OPTION} | |||||||
| ID | |||||||
| node_ID1 | node_ID2 | SN | SS | N | M |
Definition
| ID | Weld identifier. (Integer) |
| node_ID1 | Node identifier 1. (Integer) |
| node_ID2 | Node identifier 2. (Integer) |
| SN | Normal tensile force at failure.
(Real) |
| SS | Normal shear force at failure.
(Real) |
| N | Exponent for the normal force. (Real) |
| M | Exponent for the shear force. (Real) |
- This keyword maps to spring element (/SPRING) and property (/PROP/TYPE25 (SPR_AXI)) and (/SENSOR/TIME).
- The failure is defined with the following expression:
