*DATABASE_HISTORY_NODE
LS-DYNA Input Interface KeywordDefines a list of nodes for output in time history file.
(1) (2) (3) (4) (5) (6) (7) (8)
*DATABASE_HISTORY_NODE_{OPTION}
If OPTION = None (not defined)
NOD_ID1 NOD_ID2 NOD_ID3 NOD_ID4 NOD_ID5 NOD_ID6 NOD_ID7 NOD_ID8
Etc.
If OPTION = SET
SET_ID1 SET_ID2 SET_ID3 SET_ID4 SET_ID5 SET_ID6 SET_ID7 SET_ID8
Etc.
If OPTION = LOCAL
NOD_ID1 CID REF
NOD_ID2 CID REF
etc.
If OPTION = SET_LOCAL
SET_ID1 CID REF
SET_ID2 CID REF
etc.
Definition
OPTION
None
The listed nodes are output in the global coordinate system.
LOCAL
The listed nodes are output in the local coordinate system (fixed or moving).
SET
The nodes defined in the set are output in the global coordinate system.
SET_LOCAL
The nodes defined in the set are output in the local coordinate system (fixed or moving).
NOD_IDi Node identifier.
(Integer)
SET_IDi Node set identifier.
(Integer)
CID Local coordinate system identifier used for output.
(Integer)
REF The node output is in:
= 0
A fixed coordinate system.
= 1
A moving coordinate system defined by nodes.
(Integer)
  1. This keyword maps to /TH/NODE.
  2. A moving coordinate system based on nodes is used when REF=1.
  3. The SET_ID should contain only a list of nodes. It cannot be a set of set.
