*DEFINE_VECTOR_NODES
LS-DYNA Input Interface KeywordDefine a local vector direction with nodes.
(1) (2) (3) (4) (5) (6) (7) (8)
VID N1 N2
Definition
VID Vector identifier.
N1 Node to define tail of the vector.
(Real)
N2 Node to define head of the vector.
(Real)
  1. This keyword maps to /SKEW/MOV.
  2. The option “_TITLE” can be added to the end of this keyword. When “_TITLE” is included, an extra 80 characters long line is added after the keyword input line which allows an entity title to be defined.
