*ELEMENT_SEATBELT_RETRACTOR
LS-DYNA Input Interface KeywordDefines a 1D seat belt retractor element.
(1) (2) (3) (4) (5) (6) (7) (8)
RID RNID REID SENS_ID1 SENS_ID2 SENS_ID3 SENS_ID4
Tdelay PULL FCT_L FCT_UL FEED
Definition
RID Retractor identifier.
(Integer)
RNID Retractor node identifier.
(Integer)
REID Seat belt element identifier attached to the retractor.
(Integer)
SENS_ID1 Sensor for retractor activation.
(Integer)
SENS_ID2 Sensor for retractor activation.
(Integer)
SENS_ID3 Sensor for retractor activation.
(Integer)
SENS_ID4 Sensor for retractor activation.
(Integer)
Tdelay Time delay.
(Real)
[ s ]
PULL Seat belt pull length for locking.
(Real)
[ m ]
FCT_L Load curve identifier.
(Integer)
FCT_UL Unload curve identifier.
(Integer)
FEED Feed element length.
(Real)
[ m ]
  1. This keyword maps to /RETRACTOR/SPRING.
  2. First non-zero sensor is used to activate pretensioner. Time delay Tdelay is added to the sensor activation.
