*LOAD_GRAVITY_PART
LS-DYNA Input Interface KeywordDefines gravity load applied to a part or to a set of parts.
(1) | (2) | (3) | (4) | (5) | (6) | (7) | (8) |
*LOAD_GRAVITY_PART_{OPTION} |
If OPTION = <Blank>
PID | DOF | Fct_ID | Fscaley |
If OPTION = SET
SID | DOF | Fct_ID | Fscaley |
Definition
OPTION |
PID | Part ID where gravity load is
applied. (Integer) |
SID | Set part ID where gravity load is
DOF | Direction of gravity load.
Fct_ID | Curve identifier for gravity acceleration load as function of
time. (Integer) |
Fscaley | Scaling coefficient applied to the ordinate of the gravity
curve. Default =1. 0 (Real) |
- This keyword maps to /GRAV.
