Plane
- Click the Body collector and select the body constrained by the constraint mate.
- Click the first Point collector and select the origin of the plane axis.
Use the second Point collector to select the point that
defines the axis of the plane, or, using the drop-down menu to the left of the
collector, select Vector and define a vector.
Note: The marker on Body 1 (I marker) is defined at the origin of the plane and the Z axis of the marker is oriented along the direction defined by the Point|Vector that defines the plane normal. The same applies to the marker on Body 2 (J marker) in the case of the Geometry2 tab.
