Attribute Definitions
The following tables provide detailed descriptions for Particle, Geometry, Contact, and Collision attributes.
Particle Attributes
Attribute Description
Angular Velocity Indicates the speed at which an object rotates.
Charge Indicates the charge which is an electrical property of particles (such as electrons and protons) which causes them to attract and repel each other. A material with an excess of electrons has a negative charge; and a material with an absence of electrons (or an excess of protons) has a positive charge. Materials with a balanced number of electrons and protons are called 'neutral'. Positive and negative charges attract each other.
Compressive Force Indicates the sum of the surface normal force magnitudes.
Coordination Number Indicates the number of contacts that a particle has with the spheres of another particle at any given point in time. The following image of a 3-sphere particle shape represents four particles placed on top of each other.
The base and top particles have a coordination number of 3, as each particle is in contact with 3 spheres of the middle particles. The middle two particles have a coordination number of 6 as they are in contact with 3 spheres of the particle above and 3 spheres of the particle. The Particle-Geometry contacts are not counted in the coordination number.
Diameter Indicates the diameter of the particle (based on the largest X, Y, or Z component of the bounding box around the particle).
Distance Indicates the distance between the center of a particle from a reference point or plane.
Electrostatic Force Indicates the force of interaction between charged particles, measured in Newtons. The force is calculated using the screened Coulomb force equation.
ID Indicates the unique ID of a Geometry element, particle surface, particle, and collision.
Moment of Inertia Indicates a measure of a particles resistance to a change of momentum for a sphere defined as:
I= 2 5 m r 2 MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysaiabg2 da9maalaaabaGaaGOmaaqaaiaaiwdaaaGaamyBaiaadkhadaahaaWc beqaaiaaikdaaaaaaa@3C26@
Kinetic Energy Indicates the kinetic energy defined as:
K e = 1 2 m υ 2 MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGLbaabeaakiabg2da9maalaaabaGaaGymaaqaaiaaikda aaGaamyBaiabew8a1naaCaaaleqabaGaaGOmaaaaaaa@3E14@
where v is the velocity magnitude of the particle.
Mass Indicates the magnitude of the gravitational force on a particle defined as:
m=Vρ MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyBaiabg2 da9iaadAfacqaHbpGCaaa@3A88@
Number of Particles Indicates the total number of particles in a simulation (or bin group) at that point in time. In a bin group, you can use the Total over time option. This will produce a cumulative particle count for any particles that pass through that bin group. The total over time option can only be used for bin groups with 1 bin.
Orientation Indicates the alignment of a particle in relation to Cartesian space. It is represented as a 3X3 matrix that defines the rotation of the particle from its original orientation (as defined in Creator and assigned an identity matrix).
Position Indicates the x, y, or z position of the center of the particle.
Potential Energy Indicates the potential energy defined as:
Pe=mgh MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamiuaiaadw gacqGH9aqpcaWGTbGaam4zaiaadIgaaaa@3B85@
where m is the particle mass, g is the gravity, and h is the distance between the center of mass of the particle and the defined “ground” level. If the gravity is acting in negative Z, the ground level is z=0.
Residence Time Indicates the measure of how much time a particle has existed in the simulation. “Residence time = Simulation Time - Particle Creation Time”.
You can set the simulation time by navigating to Analyst > File > Export Simulation Deck. This option will impact the Residence Time shown on the particles following the equation “Residence time = Simulation Time - Particle Creation Time”
Rotational Kinetic Energy Indicates the energy defined as:
0.51 ω 2 MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaaGimaiaac6 cacaaI1aGaaGymaiabeM8a3naaCaaaleqabaGaaGOmaaaaaaa@3B91@
where I is the inertia, and ω is the angular velocity magnitude.
Time Indicates the real time it takes for an event to occur.
Torque Indicates the tangential contact force * particle radius.
Total Energy Indicates the sum of the kinetic energy, rotational kinetic energy, and potential energy of a particle.
Total Force Indicates the resultant unbalanced forces on a particle or Geometry element in x, y, and z.
Velocity The velocity of the particles is defined as the rate of change of displacement (in x, y and z)
Voidage Indicates the percentage of space not taken up by particles. Voidage can be obtained by creating a Grid Bin and Voidage query. The Voidage property is defined as:
Voidage= V bin − V particles V bin X 100 MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOvaiaad+ gacaWGPbGaamizaiaadggacaWGNbGaamyzaiabg2da9maalaaabaGa amOvamaaBaaaleaacaWGIbGaamyAaiaad6gaaeqaaOGaeyOeI0Iaam OvamaaBaaaleaacaWGWbGaamyyaiaadkhacaWG0bGaamyAaiaadoga caWGSbGaamyzaiaadohaaeqaaaGcbaGaamOvamaaBaaaleaacaWGIb GaamyAaiaad6gaaeqaaaaakiaadIfacaaMc8UaaGymaiaaicdacaaI Waaaaa@5428@
where Vbin is the volume of the defined bin, and Vparticle is the sum of the volume of all the particles inside the bin. Voidage, therefore, does not consider the overlap between particles, which quantifies the deformation of the particles. A particle which overlaps two or more bins will only be counted in the bin that contains the particle center of mass.
Volume Indicates the amount of space that a particle takes up.
Geometry Attributes
Charge Indicates the electrical property of Geometries (such as electrons and protons). A material with an excess of electrons has a negative charge; a material with an absence of electrons (or an excess of protons) has a positive charge. Materials with a balanced number of electrons and protons are called 'neutral'. Positive and negative charges cause an attractive force to be applied between the elements (Particle-Geometry).
Compressive force Indicates the sum of the surface normal forces on the Geometry.
Distance Indicates the distance from the center of a Geometry node from a reference point or plane.
Electrostatic force Indicates the force of interaction between charged elements, measured in Newtons. The force is calculated using the screened Coulomb force equation.
Node 1, 2, 3 Indicates the position (x, y, and z) of the Geometry nodes.
Number of geometry elements Indicates the sum of the Geometry elements. Geometries are split into triangular elements.
Position Indicates the X, Y, or Z position of the center of the Geometry element.
Torque Indicates the tangential contact force * distance, where distance is the distance from the center of mass to the contact point.
The torque is calculated from the individual torque and moment about each individual Geometry element which is then converted to the torque on the whole Geometry about the center of mass.  The torque can be plotted or exported along the x, y, and z axis.
Total Force Indicates the resultant unbalanced forces on a particle or geometry element in x, y , and z.
Velocity Indicates the rate of change of displacement of the individual Geometry nodes.
Contact Attributes
Contact vector 1,2 Indicates the vector connecting the contact point to the center of the particle when two particles collide.
Distance Indicates the distance from the point of contact to a user-defined point or plane.
Normal force Indicates the force that is created when two bodies are in direct contact with one another. It always acts perpendicular to the body that applies the force. The force depends on the contact model used, and will be a spring force with a damping component. The reported force on particles includes damping forces, and the reported force on Geometries is the undamped force.
Normal overlap Indicates the normal deformation of a particle. The normal overlap N between two particles i and j at positions pi and pj with radii ri and rj is defined as:
N= r i + r j − p 1 − p j MathType@MTEF@5@5@+= feaahyart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOtaiabg2 da9maabmaabaGaamOCamaaBaaaleaacaWGPbaabeaakiabgUcaRiaa dkhadaWgaaWcbaGaamOAaaqabaaakiaawIcacaGLPaaacqGHsislda qadaqaaiaadchadaWgaaWcbaGaaGymaaqabaGccqGHsislcaWGWbWa aSbaaSqaaiaadQgaaeqaaaGccaGLOaGaayzkaaaaaa@45D3@
Number of contacts Indicates the number of contacts or impacts occurring between elements at data write-out points. In other words, the contact is in progress when the write-out takes place. The contact has an associated force, position and so on - these are discrete values. If two elements stay in contact with each other for some time. For example, over four write-out points, four contacts will be stored and each of these may have a different force, position and so on
Position Indicates the central point between two elements at the point in time when a contact starts.
Tangential force Indicates the force from the tangential overlap.
Tangential overlap Indicates the tangential displacement of the contact point up to the point at which the contact ends or the particle begins to roll or slip. The tangential overlap represents the tangential deformation of a particle.
Collision Attributes
Average normal force Indicates the average normal force over the duration of a single collision.
Average tangential force Indicates the average tangential force over the duration of a single collision.
Distance Indicates the distance from the collision position to a user defined point or plane.
Duration Indicates the total time that the two elements involved in a collision are in contact.
End time Indicates the time at which the collision ends.
ID Indicates a unique number which can be used to track the unique collision and the elements involved.
ID Element n Indicates a unique number for each element in a collision.
Maximum normal force Indicates the maximum normal force experienced during a single collision.
Maximum tangential force Indicates the maximum tangential force experienced during a collision.
Normal energy loss Indicates the energy lost during a collision due to the normal overlap.
Number of collisions Indicates the number of completed collisions. Only completed collisions are counted, and collisions in progress (contacts) are not counted.
Position Indicates the central point between two elements at the point in time when a collision starts. The collision position is written out on completion of the collision.
Relative velocity Indicates the relative velocity of two elements in a collision is Va - Vb.
Note: This value is calculated from the contact points and not the particle centers.
Indicates the value calculated from the contact points and not the particle centers.
Relative velocity normal Indicates the relative normal velocity of two elements in a collision is Vna - Vnb.
Relative velocity tangential Indicates the relative tangential velocity of two elements in a collision is Vta - Vtb.
Start time Indicates the point in time when the first contact of a collision occurs.
Tangential energy loss Indicates the energy lost during a collision due to the tangential overlap.
Total energy loss Indicates the sum of the normal and tangential energy loss.
Velocity of element A/B Indicates the velocity magnitude of an element involved in a collision. Element A will have the lowest ID number and element B will have the highest.
