Command Line Example Commands
This section provides examples of the default processing options, and how to specify processing options and run simulation and export data.
Default Processing Options
- Create and save a simulation deck using EDEM Creator.
- Open a console (cmd) window then enter the following
command:
The deck rewinds to the beginning, and then each Time Step is processed. A message is displayed once complete.edem.exe --console -i "c:\My documents\edem\mysim.dem" --rewind - Open the deck and use the EDEM Analyst to perform post-processing.
Specify Processing Options
- Open a console (cmd) window then change the folder to the EDEM
binfolder. - Enter the following
command:
edem.exe --console -i "c:\My documents\EDEM\mysim.dem" –p 4 –r 10The simulation is run using four processors for a total run time of ten seconds.
Run Simulation and Export data
command:
edem.exe --console -i "c:\My Documents\EDEM\mysim.dem" -–rewind –ePC “c:\My Documents\EDEM\mysimdata.csv”The simulation rewinds and then runs using the default processing flags. It then exports particle and contact data to a
.csvfile.
Run Simulation and Export data based on Deck Configuration
- Switch to EDEM Analyst and then select .
- Define the export queries then specify the file name.
- Click Close.
- Go to EDEM Creator and save your deck.
The configuration file is updated with details of the export queries.
command:
edem.exe --console -i "c:\My Documents\EDEM\mysim.dem" -–rewind –e “c:\My Documents\EDEM\mysim.dfg”The simulation rewinds and runs using the default processing flags. It then exports data based on the queries defined in the configuration file of the deck.
