Materials database
You can store and transfer material, interaction data, Meta-Particles, and Material Block data in a database file between simulations.
By default, the Materials Database (
MaterialsDB.h5) is installed at folder.Note: Bulk Materials also contain the Particle Shape and Size Distribution information. -
Update the location information by navigating to and then browsing to the new location.
Note: The Materials Database supplied with EDEM does not contain example material types.
