Add Equipment Material
You can add Equipment material to a model
Right-click Equipment Material in the Creator Tree and
select Add Equipment Material, or use the
icon to add the material.
Right-click the new material in the Creator Tree and select Rename
Material, or click the
icon
to rename the material as required.
- Specify values for the Poisson's ratio, Solids Density, Shear modulus (or Young’s Modulus), and Work Function (if applicable).
Optionally:
- Right-click the new material in the Creator Tree and select
Copy Material, or click the
icon to create a duplicate of the currently
selected material. - Right-click the new material in the Creator Tree and select
Delete Material, or click the
icon to delete the material from a
model.
