Define Interactions Between Materials
You can define interactions between the materials during a range of operation and process conditions.
- Select the first material from the list of Equipment Materials in the Creator Tree.
Click the
icon in the
Interactions section.
- In the Select Material dialog box, click Select a Bulk Material.
- Specify values for the Coefficient of Restitution, Coefficient of Static Friction, and Coefficient of Rolling Friction.
