Select Geometry Sections
You can select Geometry sections by clicking the required Geometry in the Viewer window. The Geometry in the Creator Tree is highlighted.
You can select multiple geometries in the Creator Tree by expanding the Tree and
holding down the Ctrl key while selecting the geometries. The advantage of this
method is that once multiple Geometries are selected, the Material can be changed or
assigned for all selected Geometries using the option. Alternatively, you can delete multiple Geometries using the
Delete key or the
icon.
