Factories
You can use Particle factories to define where, when, and how Particles/Meta-Particles appear in a simulation. The following types of particle factories are available - Static, Dynamic, Block, Volume Packing, and Recorded.
Creating Particle Factories
Any virtual surface or volume (physical or virtual) can be converted into a particle
factory.
Note: Factories can only be created if a Bulk
Material has been defined. A simulation can comprise any number of particle
factories.
- Select the Geometry section you want to use as a factory.
- Right-click and select Add Factory/Add Material Block or
click the
icon. Optionally, select Plugin
Factories from the expanded Geometries tab and right-click to
import your own custom particle factory. For more information about custom
particle factories, see the EDEM
Programming Guide. - To switch between factory types, right-click and then select Change Factory Type.
