Create Bins
EDEMpy offers methods for binning objects using the
BoxBin and CylinderBin classes.
To import classes, use the following:
from edempy import BoxBin, CylinderBinBoxBinis defined by an origin[x, y, z]and edge lengths.CylinderBinis defined by the Start and End points[x, y, z], and a radius. -
To get the number of Time Steps in your deck from EDEMpy, use the following:
# To get the last timestep index value tstep = deck.numTimesteps - 1 -
To search for any arbitrary list of objects inside a bin, pass two arguments to
the
getBinnedObjects()function.Exampleboxbin = BoxBin([-0.25, 0.0, 0.0], 0.3, 1.0, 0.2) ids = deck.timestep[tStep].particle[0].getIds() pos = deck.timestep[tStep].particle[0].getPositions() binned_ids = boxbin.getBinnedObjects(ids, pos)The
getBinnedObjects()function also accepts arguments forqueryType(‘max’, ‘min’, ‘average’, or ‘total’) and transform where you can specify a 4x4 transformation matrix for translating and rotating the bin. Use this with thegetTransformMatrix()function on Geometries to allow the bins to track Geometry motion. -
To read binned properties, use the
getBinnedProperty()function to collect binned particle, contact, and bond data.binnedAveVel, x, y, z = deck.timestep[tstep].particle[0].getBinnedProperty(50, 50, 50, option='velocity’, average=True)This returns the binned average velocity for particle type 0, and the x, y, and z positions of the bins. It is useful for displaying EDEM data as a continuum, and plotted using
Matplotlibfunctions such ascontour().You can also use it to calculate custom properties, such as the segregation index.
By default, the bin’s max and min coordinates match the simulation domain, but you can also pass custom limits. The default option returns IDs.
