For cable harnesses, there is a distinction between a local circuit device ground and
the global installation ground.
The multiconductor transmission line (MTL) method
supports a distinction in the concepts local circuit device ground and global
Figure 1. An example showing the distinction between a local circuit device ground and
the global installation.
For the combined MoM/MTL harnesses, the device ground indicates the
transitioning point from circuit to full wave solver. Connections beyond the device
ground should be included in the full wave model.
Figure 2. An example showing the transitioning point from circuit to full wave
solver.
