Split Interactive
Use the Split: Interactive tool to quickly create fixed points on surfaces and edges, and split surfaces with lines. You can also remove fixed points from surfaces or surface edges to unsplit them.
From the Geometry ribbon, click the tool.
Click and drag on a surface to split the surface with a line.
- To add a fixed point, left-click on a surface or surface edge.
- To split the line at a selected location, left-click on a free line.
Note: Suppression of fixed points considers break angle. The angle is defined in .The surface is split along the new line.
Tip: Use snap points to create fixed points at predefined locations on the
model, such as end, middle, and center points. To remove the fixed points or split
lines, press the hold Shift and select the point or
line.
