Split with Surfaces
Use the Split: Surfaces tool to split surfaces and solids using surfaces.
From the Geometry ribbon, click the tool.
- Select Surfaces or Solids from the Target selector on the guide bar.
- Select geometry.
- Optional:
On the guide bar, click
to define split
options.
- On the guide bar, select Surfaces.
- In the modeling window, select the surface(s) used to split.
- Optional:
Review the split sections.
Restriction: Only available when splitting solids.
- Click Split on the guide bar.
