Split with Planes
Use the Split: Planes tool to split lines, surfaces, or solids.
From the Geometry ribbon, click the tool.
- Select Lines, Surfaces, or Solids from the Target selector on the guide bar.
Select target geometry then define how to split.
Option Description Lines or Surfaces - Click Tool on the guide bar.
- Use the Vector tool to adjust the position of the split plane.
Solids Select Plane, Nodes, or Points from the Tool selector on the guide bar. - Plane
- Left-click to place the plane on the model. Use the Vector tool to adjust the position of the split plane.
- Nodes
- On a meshed solid, select nodes to define split lines.
- Points
- Select at least three points forming a plane to trim solids.
- Optional:
Click the Review button on the guide bar to preview the
split sections, as shown below on the left.
Restriction: Only available when splitting solids with planes.Deselect sections by holding Shift and left-clicking to cut the solid at only the desired locations, as shown below in the middle. The final result is shown on the right.
- Click Split on the guide bar.
Tip:
- Select a splitting plane using reference entities or features that are disconnected from the geometry you want to split, including points in space.
- You can modify your surface selection after selecting a splitting plane. Split preview lines will update appropriately.
- Use snap points to snap the splitting plane to predefined points on lines and surfaces, such as middle and end points. Clicking a snap point automatically selects attached surfaces/solids.
