Adjust Ride Height
Use the Ride Height tool to adjust the heave, pitch, and roll of the model.
Adjust Heave
From the Setup ribbon, Ride
Height tool group, click the Heave
tool.
- In the modeling window, select the dimension for the desired axle.
In the microdialog, enter a value for height and press
Enter.
Adjust Roll and Pitch
Height tool group, click the Roll and
Pitch tool.
Figure 3.
- Optional:
Select fixed parts.
- From the guide bar, select Fixed Parts.
- In the modeling window, select parts you would like to remain stationary.
All wheel parts are stationary by default. - From the guide bar, select Ride Height.
In the modeling window, click the dimensions of the
desired wheels.
Restriction: Only three dimensions can be active at a given time.The selected dimensions are activated.Tip: To deactivate a dimension, hold Ctrl and click the desired dimension.
Edit the dimension height by completing one of the following:
- In the microdialog, enter a value for height and
press Enter.
Figure 4.
- In the microdialog, click
and use the graphical manipulators to adjust
the reference location.Figure 5.
Tip: To reset a dimension value, click
in the microdialog. - In the microdialog, enter a value for height and
press Enter.
Position the vehicle by completing one of the following:
to position the vehicle and continue adjusting
the pitch and roll. - From the guide bar, select
to position the vehicle and exit the
tool.
