Create FOS Materials
Creating materials with FOS properties differs slightly from creating materials with SN/EN properties.
Select the FOS fatigue module to create FOS materials.
Click the Material tool.
The Assign Material dialog opens. - Click the My Material tab.
Click
to create a new material.
- Edit the name of the newly created material and any relevant properties.
Select an input type from the TFL Input drop-down menu.
The TFL field can be used to define either a value (constant slope) or a table (multiple slopes) to specify the failure zone.
Define the TFL parameters from the FOS tab.
Option Description Real - Enter a Torsion Fatigue Limit value.
- Enter a Hydrostatic Stress Sensitivity value.
- Enter Safe Zone Angle (STHETA) and Shear Threshold (SSHEAR) values to help determine safe zones for the FOS calculation.
- Click Plot and Save.
The plot is updated and the table is populated with CSV values.
Table - Click
. - Browse for an import a file containing Hydrostatic Pressure and Shear Stress values.
