HM_ExtAPI::CADDocumentGetType()
Returns the type of the model assembly hierarchy document.
bool CADDocumentGetType(
const HM_CAD_Document & doc,
HM_ExtAPI::DocType & doc_type
HyperMesh Ext API Function
Type classification of the model assembly hierarchy documents reflects the difference between model parts that contain actual geometry data and assemblies containing references to different parts or sub-assemblies along with corresponding transformations to the global model coordinates system.
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Different CAD systems use different name conventions to distinguish between two types of
model hierarchy documents. The following table type translation for the CAD systems
supported within API.
| CAD System | Assembly | Part |
| HM_ExtAPI | DOC_ASSEMBLY | DOC_PART |
| CATIA | CATProduct | CATPart |
Requires including hm_extapi.h.
- doc
- [in] - Handle to document object that was returned by previous calls to API functions.
- doc_type
- [out] - Document type. When function returns, this parameter can have one of following values.
None.
