HM_ExtAPI::CreateSurfaceTorus()
Creates torus surface object.
bool CreateSurfaceTorus(
HM_EntityGeometrySurface& new_torus,
const HM_Point& origin,
const HM_Vector& normal,
const HM_Vector& uorigin_dir,
double base_radius,
double tube_radius,
double tube_phase,
bool reverse_u
HyperMesh Ext API Function
The function creates the surface object of the type HM_ExtAPI::TORUS().
The torus is defined by a circular spine and a circular cross-section at each point of the spine. The spine of a torus is defined by a center point C, normal n, and radius R. The circular cross-section is defined by a minor radius r.
The torus is parameterized by angular parameters U and V. The V-parameter is the latitude with positive direction in the direction of the torus normal n. The value V = φ corresponds to the largest V-isoparametric circle on the tube of the torus.
The U-parameter is the longitude with positive direction in counter clockwise direction around the torus normal n in case the value of the parameter reverse_u is false. The direction of U-parameter is in clockwise direction around the torus normal n in case the value of the parameter reverse_u is true. The vector u defines the direction from the center of the torus C to the circle of constant U=0 parametric isoline of the torus.
The points on the surface of the torus can be calculated parametrically as
S(U, V) = C + r n sin(V-φ) + [ R + r cos(V-φ) ] [ u cos U + q sin U ]
u = U - n (nU) , n = N / | N |
| Parameters used by CreateSurfaceTorus | Torus parameters |
| origin | C |
| normal | N |
| uorigin_dir | U |
| base_radius | R |
| tube_radius | r |
| tube_phase | φ |
| reverse_u | If false then q = n X u, If true then q = u X n |
If the function succeeds, the return value is true. If the function fails, the return value is false. To get extended value information, call HM_ExtAPI::GetLastErrorCode().
Requires including hm_extapi.h.
- new_torus
- [out] - Handle to new surface object.
- origin
- [in] - Center point of torus circular spine.
- normal
- [in] - Vector normal to the plane of the spine.
- uorigin_dir
- [in] - Vector that defines position of the tube circle corresponding to U=0 parameter.
- base_radius
- [in] - Spine circle radius.
- tube_radius
- [in] - Tube radius.
- tube_phase
- [in] - Parameter shift on the tube. See Description above.
- reverse_u
- [in] - Flag that defines direction of constant V parametric lines along the tube of the torus. The value of false indicates counter clockwise direction of constant V parametric lines with respect to the normal direction. The value of true indicates clockwise direction of constant V parametric lines.
None.
