Tcl Mathematical Expressions
In Tcl, mathematical expressions are evaluated using the expr command. This command works with integers, floating point values and logical (Boolean) values. There are many arithmetic operators and built-in math functions in Tcl.
For more in-depth explanations and a complete listing, referred to http://www.tcl.tk/man/ or to a Tcl/Tk handbook.
An example of calculating the circumference of a circle with radius of 6:
set circumference [expr 2*(2*asin(1.0))*6.0]
puts $circumference
37.6991118431Variable references can be used with the expr
command as
well.
set pi [expr 2*asin(1.0)]
set radius 6.0
set circumference [expr 2*$pi*$radius]
puts $circumference
37.6991118431It is also possible to use nested commands inside of expr.
set radius "radius"
set circumference [expr 2*$pi*[string length $radius]]
puts $circumference
37.6991118431It is important to notice the difference between using integer values and floating point
values when doing arithmetic
operations.
set using_integer [expr 1/9]
set using_float [expr 1/9.]
puts $using_int
0
puts $using_float
0.111111111111It is recommended practice to use curly braces to group expr commands and improve the
efficiency of the Tcl byte code compiler. This helps to preserve the
precision that may be lost by converting between strings and numeric values. This in turn
speeds up the evaluation of the
expression.
set circumference [expr {2*(2*asin(1.0))*6.0}]
set pi [expr {2*asin(1.0)}]
set radius 6.0
set circumference [expr {2*$pi*$radius}]It also eliminates the possibility of not getting an expected value returned due to the
precision lost in the string to numeric value
conversion.
set var1 [expr {sqrt(2.0)}]
puts $var1
1.41421356237
set var2 [expr $var1 * $var1]
puts $var2
1.99999999999
set var2 [expr {$var1 * $var1}]
puts $var2
2.0In HyperWorks, the default number of significant digits
returned is 12. The Tcl variable tcl_precision allows
you to query and set the number of significant digits
returned.
puts $tcl_precision
12
set var1 [expr 1/9.]
0.111111111111
set tcl_precision 17
puts $tcl_precision
17
0.11111111111111111
