Tcl Procedures
Procedures organize a repetitive group of commands into a logical block and allow for arguments to be parameterized. They improve performance and memory because a procedure’s commands and variables only exist within the scope of the procedure.
This means that variables created inside a procedure only exist while the procedure is executed and are destroyed when the procedure returns.
proc name {?arg1? ?arg2? etc…} {body}After a procedure is defined, it is used just like any other Tcl command. The name of the procedure becomes a new Tcl command name and is called just like any standard Tcl command. In this way, it is also possible to redefine (or undefine) the function of existing Tcl commands.
proc curve_info {curve_reference color} {
puts "Curve reference = $curve_reference";
puts "Curve color = $color";
curve_info p1w1c1 5;
Curve reference = p1w1c1
Curve color = 5proc node_info {args} {
foreach node $args {
puts "Node = $node";
node_info node1 node2 node3;
Node reference = node1
Node reference = node2
Node reference = node3proc node_info {node_list} {
foreach node $node_list {
set node_list "node1 node2 node3";
node_info $node_list;
Node reference = node3proc node_info {args} {
if {[llength $args] == 0} {
puts "No nodes are selected";
return;
curve_info;
No curves are selected
curve_info node1 node2 node3;
Node = node1
Node = node2
Node = node3proc add_three_numbers {num1 num2 num3} {
set sum [expr $num1 + $num2 + $num3];
return $expression;
set sum [add_three_numbers 2 4 5];
puts $sum;
11Procedure names, by default, are defined in the global scope (top level) of a Tcl script. Any variables that are defined outside of a procedure are also part of the global scope and are called global variables. Different namespaces exist for procedure names and global variables so it is possible to have procedures and variables with the same name without issue. It is also possible, and recommended, to use the Tcl namespace facility to manage the scope of procedures and variables.
set element_list "1 2 3 4 5";
proc element_info {} {
puts $element_list;
set node_list "10 20 30 40";
puts $node_list;
element_info;
can't read "element_list": no such variable
10 20 30 40
puts $element_list;
1 2 3 4 5
puts $node_list;
can't read "node_list": no such variableproc node_info_1 {} {
puts $node_list;
puts $node_list;
proc node_info_2 {} {
puts $node_list;
puts $node_list;
node_info_1;
10 20 30 40
node_info_2;
10 20 30 40As a general rule, it is good practice to create focused procedures that have specific functions which are modular and reusable. This allows the procedure to perform a specific operation that allows other developers to easily see what function the procedure performs. It also allows procedures to be reused in other scripts that may require similar functions.
