Tcl Variables
Tcl variables are always strings even when they contain numeric values. For most applications, using strings has no effect, but occasionally a HyperWorks application will expect a real number and passing a string will cause an error.
Tcl variables may not contain tabs, spaces, carriage returns, nor the following characters: $ [ ] { } . #
The set command is used to associate variables with data.
set var1 "one plus one equals";
set var2 "2";set can also return the value of a variable. This can be useful when
using one variable to reference the name of another
variable.
set var1 "one plus one equals 2";
set var1;
set var2 "var1";
set var2;
var1
set [set var2];
one plus one equals 2Placing a $ before a variable name will replace (substitute) the variable with its
associated
value.
puts "The expression: $var1 $var2";
The expression: one plus one equals 2To set a variable to
nothing:
set var2 "2";
set var2 {};
puts $var2;Tcl returns a carriage return.
To remove a variable from the current script use the unset command. This is handy because
there are commands to check a variables
existence.
set var2 "2";
unset var2;
puts $var2;
can't read "var2": no such variable
