mdlIModelClient GetModelHandle
Gets the handle of the root node of the current model.
mdlIModelClient_Handle GetModelHandle handle_name
MotionView Tcl Query
This command retrieves the handle of the Model which is loaded in the client (with mdlIModelClient_Handle as the handle). This handle can further be used to edit the properties of the entity or to get the child handle.
- handle_name
- The handle name of the MODEL.
To get the handle of the Model which is currently loaded in the client:
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetModelHandle mo
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;Errors
Returns 0 if successful, otherwise an error code.
