mdlIModelClient SetObjectPickExceptionList
Sets the list of objects that are an exception to the objects that can be picked from the Graphic Window.
mdlIModelClient_handle SetObjectPickExceptionList entity
MotionView Tcl Modify
This command sets the list of objects that are an exception to the objects that can be picked from the Graphic Window.
- entity
- The object to be added into the exception list.
To set the list of objects that are an exception to the objects that can be picked from the
Graphic
Window:
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl GetRootObjectHandle mo
mo InterpretEntity en Point p_0 "\"Point 0\""
en ReleaseHandle;
mcl SetObjectPickExceptionList p_0
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;Errors
Returns 0 if successful, otherwise an error code.
