mdlIModelClient SetStandardIncludeFile
Sets the standard include file for the filename specified.
mdlIModelClient_Handle SetStandardIncludeFile filename, arg_Profile
MotionView Tcl Modify
This command sets the standard include file for the filename specified.
- filename
- The filename of the standard include file for the specified profile.
- arg_Profile
- Valid arguments are:
- User
- Settings specified for the user profile
- Pref
- Settings specified in the preference file
Copy the standard include file into the present working directory, rename it as
file_standard, and run the example
below:
hwi OpenStack
hwi GetSessionHandle sess1
sess1 GetProjectHandle pro1
pro1 GetPageHandle pa1 [pro1 GetActivePage]
pa1 GetWindowHandle win1 [pa1 GetActiveWindow]
win1 GetClientHandle mcl
mcl SetStandardIncludeFile file_standard User
mcl ReleaseHandle;
win1 ReleaseHandle;
pa1 ReleaseHandle;
pro1 ReleaseHandle;
sess1 ReleaseHandle;
hwi CloseStack;Errors
Returns 0 if successful.
