plt3DICurveGroup CopyCurve
Copies a curve to the clipboard.
plt3DICurveGroup_handle CopyCurve index
Tcl Query
All curve groups share a single clipboard, which can contain (in theory) one or more curves. The current implementation limits the number of curves that can be on the clipboard at a time to one (or zero). Copying a new curve to the clipboard will erase a curve previously stored there.
- index
- The index of curve to copy (one-based).
To copy an existing curve from an existing curve
group:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName
myGroupName CopyCurve 1Errors
None.
