plt3DICurveGroup PasteCurve
Gets the curve’s visibility state.
plt3DICurveGroup_handle PasteCurve index
Tcl Query
All curve groups share a single clipboard, which can contain (in theory) one or more curves. The current implementation limits the number of curves that can be on the clipboard at a time to one (or zero).
- index
- The index of where to insert the copied curve (one-based).
To paste a curve to an existing curve
group:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName
myGroupName PasteCurve 1Errors
None.
