plt3DICurveGroup GetNumberOfCurves
Gets the current number of curves in the curve group.
plt3DICurveGroup_handle GetNumberOfCurves
Tcl Query
A curve group can contain any number of curves. Unlike in the case of a waterfall, the curves are assumed not to be related or to share an orientation.
Returns the number of curves (an integer).
To get the number of curves in an existing curve
group:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName GetNumberOfCurvesErrors
Returns an empty string if the value is not defined.
