plt3DICurveGroup SetMetaData
Associates a named meta-data value with the curve.
plt3DICurveGroup_handle SetMetaData name value
Tcl Modify
Metadata can be any string or string representation of a number.
- name
- The name of the value.
- value
- The value itself.
To set and get a meta-data value from an existing
curve:
mySessionName GetProjectHandle myProjectName
myProjectName GetPageHandle myPageName 1
myPageName GetWindowHandle myWinName 1
myWinName GetClientHandle myClientName
myClientName GetCurveGroupHandle myGroupName 1
myGroupName SetMetaData species monkey
myGroupName GetMetaData speciesErrors
None.
