poISection AlignView
Align view from the normal direction of a planar section.
poISection_handle AlignView
HyperView Tcl Modify
This command changes the view to be aligned with the normal direction of the planar section cut.
To change the view to align with a created planar section normal
direction:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Align View
section_handle AlignView
hwi CloseStackErrors
None.
