poISection SetDisplayOption
Sets the state of the given section display option.
poISection_handle SetDisplayOption name value
HyperView Tcl Modify
This command returns the state of the given section display option.
- name
- The name of the section display option:
- “gridlines”
- Display of grid lines.
- “grixtext”
- Display of values around the grid.
- value
- The boolean value for the section display option.
To set the state of a section display
option:
hwi OpenStack
hwi GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Get gridtext status
section_handle SetDisplayOption "gridtext" true
hwi CloseStackErrors
Returns an invalid handle.
