poISection GetGridSpacingX
Gets the distance between each grid line on the local X axis for a Planar section type.
poISection_handle GetGridSpacingX
HyperView Tcl Query
This command returns the distance on the local X axis in generic model units for a Planar section type.
To get the distance between each grid line on the local X
axis:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetSectionHandle section_handle 1
section_handle GetGridSpacingX
hwi CloseStackErrors
None.
