poISection SetClipElements
Toggles the boundary element clipping state for a section.
poISection_handle SetClipElements state
HyperView Tcl Modify
This command toggles the boundary element clipping state for the section. Set to "True" enable element clipping at the section surface, or "False" otherwise.
- state
- The state to be applied to boundary element clipping.
To set the clip element status of a created
section:
hwi OpenStack
hwi GetSessionHandle sess
sess GetProjectHandle proj
proj GetPageHandle page [proj GetActivePage]
page GetWindowHandle win [page GetActiveWindow]
win GetClientHandle post_handle
post_handle GetSectionHandle section_handle [post_handle AddSection 0]
# Set clipping state
section_handle SetClipElements false
hwi CloseStackErrors
Returns an invalid handle.
