poISubcase GetDerivedSimulationLabel
Returns the derived label of the simulation of a derived subcase.
subcase_handle GetDerivedSimulationLabel simidx
HyperView Tcl Query
This command returns the derived label of the simulation corresponding to the simulation
index specified. The derived simulation label usually will be a combination of the original
subcase label and the original simulation label which is used to create this simulation of
the derived subcase.
Note: This command is different from the
GetSimulationLabel command.
- simidx
- The simulation index within the derived subcase.
For example, if you have a subcase id 1 (whose label is SC1) and it has one simulation
(whose label is T=0.0), and if you include this simulation in a derived subcase whose id is
2 (whose label is SC2).
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
set scid [result_handle AddSubcase];
result_handle GetSubcaseHandle subcase_handle $scid
subcase_handle SetDerivedType "superposition"
subcase_handle AppendSimulation 1 0;
set lab [subcase_handle GetDerivedSimulationLabel 0];
# The variable lab will have a value something like "SC1 T=0.0"
hwi CloseStackErrors
Returns nothing if an error occurred.
