poISubcase SetDerivedFunction
Returns the function type of an "envelope" derived subcase.
subcase_handle SetDerivedFunction func
HyperView Tcl Modify
This command sets the function type of the "envelope" subcase. This command should be used on an "envelope" subcase.
- func
- This argument could have any of the following values: min, max, extreme, or range.
To set the function type of an envelope subcase:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
subcase_handle SetDerivedFunction extreme
hwi CloseStackErrors
None.
