poISubcase UnloadSimulation
Unloads the simulation corresponding to the index.
subcase_handle UnloadSimulation index
HyperView Tcl Modify
This command frees the memory associated with the given simulation index. An index of -1 unloads all the steps except the current one (the current simulation cannot be unloaded).
- index
- The simulation index.
To unload a simulation
step:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 1
# Unload simulation index 2
subcase_handle UnloadSimulation 2
hwi CloseStackErrors
Returns a non-zero value if the index value is not appropriate.
