poISubcase GetSimulationScaleFactor
Returns the scale factor for a particular simulation index.
subcase_handle GetSimulationScaleFactor simidx
HyperView Tcl Query
This command retrieves the scale factor associated with a simulation step.
- simidx
- The simulation index.
To get the scale factor associated with simulation index
2:
hwi OpenStack
session_handle GetProjectHandle project_handle
project_handle GetPageHandle page_handle [project_handle GetActivePage]
page_handle GetWindowHandle window_handle [page_handle GetActiveWindow]
window_handle GetClientHandle client_handle
client_handle GetModelHandle model_handle [client_handle GetActiveModel]
model_handle GetResultCtrlHandle result_handle
result_handle GetSubcaseHandle subcase_handle 2
set sfactor [subcase_handle GetSimulationScaleFactor 2];
hwi CloseStackErrors
Returns a non-zero value.
