2025
View new features for Altair HyperWorks 2025.
Create an assembly structure from a .csv file definition.
Use the Coordinates Precision Control tool to control the node precision in the Nastran/OptiStruct output decks (GRID) card.
Round off the node coordinates (multiple nodes) to the desired precision and update the HyperMesh database.
Use the Nodal Equivalence tool to select the node location to perform direct nodal equivalence instead of running it through either component or element selection.
The Developer ribbon contains tools for automation and customization.
