Export
The Tools menu Export option allows you to access sub-menu options and dialogs for iso surface, plot styles, sets, and views.
Export Plot Styles
DefaultPlotStyles line in your preference file. Set the
path and file name to your plot styles file.-
From the Tools menu, select .
The Export Styles dialog is displayed.
- From the Save in file browser, select the directory to which you want to save your file.
Enter a file name and click Save.
This file can then be imported using the Import Plot Styles option.
Export Sets
You are automatically taken to the Set panel, and the Export Sets dialog is displayed.Note: You can also access the Export Sets dialog by clicking Export in the Set panel.
- From the Select format drop-down menu, select a file type (HyperView group definition file or Patran session file).
- From the File name file browser, select the directory and name to which you want to save your file.
- Click Save.
- Optional: Activate the Export selected sets option to export only selected sets in the panel or in the browser (if desired).
Click OK to close the dialog.
You can now import this file by clicking Import in the Set panel.
Export Views
The Export Views dialog is displayed.
This file can then be imported using the Import Views option.
Export an Iso Surface
The Export Iso Surface dialog is displayed.
- From the Select format drop-down menu, select STL.
- Click Save.
You can now open this file in HyperMesh (or another pre-processor), or a CAD tool for design review.
