Attach a Note to an Entity
From the Annotate tools, click the Notes tool.
Right-click on the note to be attached to another entity and select
Edit.
Figure 2. Note Context Menu
From the floating entity editor, select the Attach Type as
Entity.
Figure 3. Note Entity Editor
- Use the Entity ID drop-down menu to select the Entity type.
Select the entity.
- Click the input collector (Node, Element, Component, or System) and
select By ID.
OR
- Pick an entity (node, element, component, or system) directly from the model in the modeling window.
select By ID.
- Once selection is complete, close the Entity Editor.
