Inspire Writer
Supported Entities
Entities supported by the Inspire writer.
- Model
- Assembly
- Part
- Solid
- Sheet
- Curve
- Point
- Axis System
- Facets/Triangles
- FE Models
Export Option
The Inspire writer uses the inspire_writer.ini file with the
following available options:
| Value | Description |
Parts |
Create part entity hierarchy as assembly and part entity in Inspire. |
Assemblies |
Create assembly and component entity as assembly and part entity in Inspire. |
Flatten |
Write entities in all components into a single Inspire part. |
All |
Export all geometry (default). |
Displayed |
Export displayed geometry only. |
on |
Export FE models (default). |
off |
Do not export FE models. |
Standard |
Write CAD geometry with standard types such as cylinder, cone, circle, and so on (default). |
BSpline |
Convert all surface geometry data into NURBS. This option may increase the output file size and be time consuming depending on the actual geometry. |
on |
Assign part name in CAD file from the representation file
name attached to part entity. Meaningful only if
off |
Assign part name in CAD file from the part entity name in the
application. Meaningful only if |
on |
Fix gaps between stitched edges and vertices to make the actual geometry of the surfaces consistent with the model topology before export, and check the topology of the model for gaps that are larger than a given tolerance between shared, non-manifold, or suppressed edges. If the gap is found to be bigger than the tolerance, the surface and edge geometries are morphed parametrically and in 3D, if necessary, to make the gap smaller than the tolerance. In addition, non-essential degenerate edges are removed. This also modifies the geometry within the application (default). |
off |
Do not perform the optimization steps. |
Unit system assigned to the data present in the application during export |
Units system in the Inspire file. |
Solid/Shell |
Export topology data similar to the application's topology data, keeping the distinction between solids and shells (default). |
Surface |
Export each surface, including solid faces, as a single surface, effectively neglecting connectivity. |
string |
Inspire version to use for export. Valid versions are 2018.1 (default), 2017.1 |
