Topology Preferences
Define topology preferences.
From the File menu, select to define the following topology preferences.
- CAD
- Show updates immediately
- CAD models from Inspire can read
parameters. This option immediately runs Inspire in the background to update the
geometry as changes happen. Note: From the Topology ribbon, Edit pull-down menu, use CAD Update to make changes and update the geometry only once.
- Inspire installation directory
- To update CAD geometry in Inspire, specify the Inspire installation directory path.
- Import Options
- Click Import Options to display the
CAD Import Preferences dialog.
- Display
- Surface lines
- The default number of u-v lines to draw on new surfaces.Note: Displaying surface lines helps visualize a surface better, but it can slow down the redraw speed of a large model. Use the Surf Lines panel to change the number of surface lines on existing surfaces.
- Cleanup Tolerance
- Geometry
- Set the cleanup tolerance to Automatic or Manual.
- Node
- For Manual, specify the tolerance used to maintain the finite element data in the model. Any two nodes are coincident if the distance between them is less than the value.
- Feature Angle
- Geometry
- Determines when to add (creating two surfaces from one) or remove (merging two surfaces into one) a new vertex to model geometry.
- Mesh
- Specify the maximum distance that the selected entity must be within to be included in the selection. When entities are selected by face, attached adjacent elements are progressively selected if the feature angle between them is less than or equal to the mesh feature angle. This also affects automatic mesh cleanup.
- Element
- Default size
- Specify a default edge length for elements, in the same units that the loaded model was created in (mm, inches, and so on). This determines the default values whenever meshing, such as in the Freeform tool.
- Element order
- Use first-order (corner nodes only) or second-order (corner and mid-edge nodes) elements when meshing.
- Beamsection default thickness
- Change the default thickness for the beamsection shell part.
- Creation
- Create mode
- Create surfaces as CAD or FE geometry.
- Create in
- Choose a method for organizing the geometry.
- Current
- Organize new geometry in the current component.
- Original
- Organize new geometry in the same component to which the selected geometry belongs. The surface is kept in the component that is chosen first.
- New
- Organize new geometry in the new part.
- Mesh organization
- Select the component to place new mesh in.
- Auto-stitching
- For tools that use surface creation, determine how new surfaces
are created and stitched to the model.
- Within same component
- Auto-stitch created surfaces to adjacent surfaces that belong to the same component.
- Across any component
- Auto-stitch created surfaces to all adjacent surfaces.
- From attached to selection
- Stitch created surfaces to the surfaces attached to the selected surfaces or edges.
- From selection only
- Only stitch created surfaces to other selected surfaces, or surfaces that have edges or vertices selected.
- Create mesh
- Select a meshing method for the newly created geometry when Mesh is selected on the guide bar.
- Topology Revision
- CAD
- Select the method for handling your model when the geometry's
topology changes.
- Delete mesh
- Deletes the mesh from the affected surfaces.
- Disassociate mesh
- Disassociates the mesh from the affected surfaces.
- Remesh
- Automatically remeshes the affected surfaces.
- Number of layers
- Define the zone to remesh or rebuild on the topology revision.
- Transformation
- Select a method to control the 2D remesh and
connectivity with the surrounding mesh on a CAD
surface transformation.
- Keep and break
- On a surface transformation, the mesh is kept in the original position without remeshing by breaking the connectivity with the surrounding mesh.
- Move and break
- On the surface transformation, the mesh moves along the surface without remeshing by breaking the connectivity with the surrounding mesh.
- Keep mesh along matched topology
- Skips the remesh when the geometry topology is matched with the finite element edge.
- Remesh tetra mesh
- Updates the tetra elements associated with the solid geometry locally when the geometry is modified with operations like Boolean, solid trim, or surface offset. If the boundary layer or hex elements are present, those are replaced with tets upon update.
- FE Geometry
- Keep mesh
- Keeps the existing mesh on the finite element topology revision.
- Remesh
- Remeshes the surrounding mesh on the finite element topology revision.
- Rebuild
- Rebuilds the surrounding mesh on the finite element topology revision.
- Number of layers
- Mesh Sync
- Element values
- Retains element properties, offsets, nodal thicknesses, orientation, and 1D element values while remeshing.
- Loads and BCs
- Retains loads and boundary conditions that are applied to nodes when remeshing.
- Sets
- When remeshing changes the model, automatically attempt to update sets accordingly.
- Advanced
- Allow 2D-3D set segment re-parenting
- Set segments applied to coincident 2D or 3D elements are re-parented to underlying elements if one is deleted.
- Allow duplicate IDs
- Allows properties in different groups to have the same ID. Duplicate properties cannot exist in the same group.
- Mixed property warning
- Displays a warning when components contain both direct and indirectly assigned properties.
