Word Document
Add pages from a Word document to the report.
- Right-click at the Report or Chapter level and select .
Or
From the Report ribbon, click the arrow next to the Add Item, then select Word Document.
- Below are the properties associated with the Word Document entity.
- Name
- You change the name property of the Word document item.Note: Once you select a Word file, the Word entity name is replaced with the selected file name.
- File Path
- Select a Word file using the file browser option.
- Page Range
- Enter the page range of the document to be imported into report.
