Import and Export CSV Files
You can import and export comma separated value files (CSV) to and from TableView.
- From the File menu, select to import a file.
From the Text Import Options dialog, select the appropriate delimiter
option.
TableView supports multiple lines of data in a single cell. To add a line break, press Alt + Enter. The Edit and Format panels are disabled if you select a cell that contains multiple lines or if you press Alt + Enter. -
Click Export > Table CSV to export a file.
Note: See Open Files for more information.
